poIAdvancedQuery WriteData
Writes the output data to files.
advancedQuery_handle WriteData filename
HyperView Tcl Query
This command is used to write the output data into the given file name.
- filename
- The name of the file (for example, advQueryResult.csv).Note: The file name can have a .csv extension.
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule extreme]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetExtreme "TopN 3"
set advQueryID [client AddAdvancedQuery]
client GetAdvancedQueryHandle advancedQuery_handle $advQueryID
advancedQuery_handle AddSimulations "current" "current"
advancedQuery_handle SetQuery "entity.id entity.value"
advancedQuery_handle SetQueryLogic "[rule_handle GetID]"
advancedQuery_handle WriteData "advQueryResult.csv"
hwi CloseStack
This command returns HW_Error, if no argument is passed to the file
        name.
