poIImagePlane GetCullAngle
Gets the culling angle setting for the image plane.
Imageplane_handle GetCullAngle
HyperView Tcl Query
When the image plane mode is 3D, HyperView compares the camera view angle to the image plane’s surface normal. When the difference is greater than the cull angle, HyperView applies transparency to the image plane. The greater the angle difference, the more transparent it becomes. The transparency effect is also multiplied by the Alpha property of the image plane. This command returns the current cull angle value.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
set ipid1 [ipc_handle AddImagePlane Logo1]
ipc_handle GetImagePlaneHandle imageplane_handle $ipid1
imageplane_handle SetFileName g:/samples2/VideoOverlay/logo1.jpg
imageplane_handle SetMode background
imageplane_handle ReleaseHandle
set ipid2 [ipc_handle AddImagePlane Video1]
ipc_handle GetImagePlaneHandle imageplane_handle $ipid2
imageplane_handle SetFileName g:/samples2/VideoOverlay/video1.jpg
puts "ImagePlane Basic Properties :";
puts "  ID =       [imageplane_handle GetID]";
puts "  Filename = [imageplane_handle GetFileName]";
puts "  Label =    [imageplane_handle GetLabel]";
puts "  Syncblock ID = [imageplane_handle GetSyncBlockID]";
puts "  Visibility = [imageplane_handle GetVisibility]";
puts "  Alpha =    [imageplane_handle GetAlpha]";
puts "  Mode  =    [imageplane_handle GetMode]";
puts "  Associated Model ID = [imageplane_handle GetAssociatedModelID]";
puts "  Cull Angle = [imageplane_handle GetCullAngle]";
puts "  Backface Visibility = [imageplane_handle GetBackFaceVisibility]";
puts "  Crop =     [imageplane_handle GetCrop]";
puts "  Stretch =  [imageplane_handle GetStretchToFit]";
puts "  Maintain Aspect =  [imageplane_handle GetMaintainAspectRatio]";
hwi CloseStackConsole Output:
  ID =       1
  Filename = g:/samples2/VideoOverlay/logo1.jpg
  Label =    Logo1
  Syncblock ID = W1:V1
  Visibility = true
  Alpha =    100
  Mode  =    Background
  Associated Model ID = -1
  Cull Angle = 20
  Backface Visibility = false
  Crop =     0.00, 0.00, 1.00, 1.00
  Stretch =  false
  Maintain Aspect =  trueErrors
None.
