poIImagePlane SetColorAlphaTarget
Sets the post-processing filter mode.
Imageplane_handle SetColorAlphaTarget mode colotStr
HyperView Tcl Modify
The image plane offers several image post-processing filters that can be run on the image or video. The ColorAlpha filter makes the target color in the image or video transparent. This command specifies the target color.
- mode
- The filter mode name. Valid values are returned by GetFilterModeList. They are different for each filter type.
- colorStr
- The target color, specified as three values between 0 and 255, representing RGB components.
hwi OpenStack
if {[catch {
    hwi GetActiveClientHandle client_handle
    client_handle GetImagePlaneCtrlHandle ipc_handle
    set ipid1 [ipc_handle AddImagePlane Logo1]
    ipc_handle GetImagePlaneHandle imageplane_handle $ipid1
    imageplane_handle SetFileName g:/samples2/VideoOverlay/Altair_logo.jpg
    imageplane_handle SetMode background
    imageplane_handle SetCrop 0 0 0.9995 0.995
    imageplane_handle SetFilterType ColorAlpha;
    imageplane_handle SetFilterMode equal;
    imageplane_handle SetColorAlphaTarget "255 255 255"
    imageplane_handle SetColorAlphaTolerance 18
    imageplane_handle SetMipMapMode Linear1
    puts "  Filter Type: [imageplane_handle GetFilterType]";
    puts "  Filter Mode: [imageplane_handle GetFilterMode]";
    puts "  Alpha Color Target: [imageplane_handle GetColorAlphaTarget]";
    puts "  Alpha Color Tolerance: [imageplane_handle GetColorAlphaTolerance]";
    puts "  MipMap Mode: [imageplane_handle GetMipMapMode]";
    client_handle Draw
} result]} {
    global errorInfo;
    puts stderr $result;
    puts "[session_handle GetError]";
    puts stderr "*** Tcl TRACE ***";
    puts stderr $errorInfo;
} else {
    puts "No errors.";
    puts "Warnings: ";
    puts "    [session_handle GetError]";
hwi CloseStackErrors
Returns HW_InvalidHandle if the image plane handle is invalid, or poIInvalidImgFilterMode if the specified filter mode is not recognized.
