poIImagePlane SetSyncMode
Sets the mode used to synchronize an image plane video with a model animation.
Imageplane_handle SetSyncMode mode
HyperView Tcl Modify
This command automatically adjusts the image plane video scaling based on the selected mode.
- mode
            - Manual (Default)
- No changes are made. The synch mode is automatically set to manual if the scaling is changed by the user.
- Length
- The scaling is adjusted so that the video and model start and stop animating at the same time.
- Framerate
- The scaling is adjusted so that the video and model animate at the same number of frames per second.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
ipc_handle GetImagePlaneHandle image_plane_handle 1
image_plane_handle SetSyncMode Length
hwi CloseStackErrors
Returns HW_InvalidHandle if the image plane handle is invalid, or HW_Error if the mode is not a valid string.
