poIImagePlane SetAssociatedModelID
Associates the image plane with the specified model.
Imageplane_handle SetAssociatedModelID id
HyperView Tcl Modify
When a tracking system is created and made active, it can be desirable for a 3D image plane to follow the tracking system. This command identifies which model, if any, the image plane should follow. This setting is only relevant if the image plane is in 3D mode, and if there is an active tracking system on that model. A value of -1 indicates no model is associated with the image plane.
- id
- A valid model ID.
# Assumes the LS-Dyna Bumper model is loaded
hwi OpenStack
if {[catch {
    session_handle GetProjectHandle project_handle
    project_handle GetPageHandle page_handle [project_handle GetActivePage]
    page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
    window_handle GetClientHandle client_handle
    client_handle GetImagePlaneCtrlHandle ipc_handle
    set ipid2 [ipc_handle AddImagePlane Video1]
    ipc_handle GetImagePlaneHandle imageplane_handle $ipid2
    imageplane_handle SetFileName g:/samples2/VideoOverlay/video1.jpg
    imageplane_handle SetMode background
    imageplane_handle ReleaseHandle
    client_handle GetModelHandle model 1
    set tsid [model AddTrackingSystem];
    model GetTrackingSystemHandle ts_handle $tsid;
    ts_handle SetNode "1 189 @ 1 2 1 188";
    model SetActiveTrackingSystem $tsid;
    imageplane_handle SetCullAngle 70
    imageplane_handle SetMode 3D
    imageplane_handle SetAssociatedModelID 1
    client_handle Draw
} result]} {
    global errorInfo;
    puts stderr $result;
    puts "[session_handle GetError]";
    puts stderr "*** Tcl TRACE ***";
    puts stderr $errorInfo;
} else {
    puts "No errors.";
    puts "Warnings: ";
    puts "    [session_handle GetError]";
hwi CloseStackErrors
Returns HW_InvalidHandle if the image plane handle is invalid.
