vidIVideo IsFilenameShown
IMPORTANT: This API is now obsolete. Please refer to the vidivideo GetMediaInfoNoteHandle API to achieve this functionality. Determines whether the filename is shown.
vidIVideo_handle IsFilenameShown
Tcl Query
This command finds whether the filename is shown on the video or not. If the filename is turned on, true is returned. If not, false is returned. If the filename is turned on, it is displayed within the annotation note.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle Video;
Video IsFilenameShown;
Success (a true or false value) or an error message is returned.
Keywords
- Tcl
- Video
- Query
