vidIVideo ShowFilename
IMPORTANT: This API is now obsolete. Please refer to the vidivideo GetMediaInfoNoteHandle API to achieve this functionality. Sets whether the filename is shown.
vidIVideo_handle ShowFilename on
Tcl Modify
This command sets whether the filename is shown in the video or not. The filename is displayed within the annotation note. It is shown in the annotation box with the frame number and time step, if they are also turned on.
- on
- A true or false value. - True
- Filename turned on.
- False
- Filename not turned on.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle Video;
Video ShowFilename true;Errors
Keywords
- Tcl
- Video
- Modify
