vidIVideo SetMeasurePoint1X
Sets the x coordinate of the first point of a static measure.
vidIVideo_handle SetMeasurePoint1X index x
Tcl Modify
This command sets the x coordinate of the first point of the measure object referenced by the given index.
- index
- The index of the measure to be changed.
- x
- The x value (in pixels) that you want to make the first measure point.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle Video;
Video AddMeasure static;
Video SetMeasurePoint1X 1 400;
Video SetMeasurePoint1Y 1 68;
Video SetMeasurePoint2X 1 600;
Video SetMeasurePoint2Y 1 68;
Video DrawMeasure;Errors
