Create Derived Load Cases
Create derived load cases in the form of linear super-position and/or envelope.
- From the Post ribbon, click the satellite icon
that appears when you hover over the Results tool.
- Right-click on a result or load case entity in the Results Browser and select Create Derived Loadcase.
Each newly created derived load case (DLC) is appended to the list and can be reviewed by clicking the review icon. DLCs are then available in all of the other result tools.
