Joint Initial Velocity: Cylindrical
Model ElementThe JointInitialvel_Cyl element defines the initial velocity for a cylindrical joint element. It allows you to specify the initial velocities for both the translational and the rotational degree of freedom.
<JointInitialvel_Cyl
joint_id = "integer"
trans_iv = "real"
rot_iv = "real">
</JointInitialvel_Cyl>
Attributes
- joint_id
- The ID of the cylindrical joint whose initial velocity is being specified.
- trans_iv
- The initial translation velocity of the cylindrical joint. The value specified is the
translational velocity of the I marker of the joint relative to the J marker of the
joint. The unit is model length units per model time unit.
A positive value implies a velocity along the z-axis of theJ Reference_Marker. A negative value implies a velocity along the negative z-axis.
- rot_iv
- The initial rotational velocity of the cylindrical joint. The value specified is the rotational velocity of the I marker of the joint relative to the J marker of the joint. The unit is radians per model time unit.
In his book, Out of Control, Kevin Kelly describes the flyball governor:
"Two leaden balls, each at the end of a stiff pendulum, swing from a pole. As the pole rotates, the balls spin out levitating higher the faster the system spins. Linkages scissored from the twirling pendulums slide up a sleeve on the pole, levering a valve which controls the speed of rotation by adjusting the steam."
The connection between the sleeve and the governor shaft may be modeled using a cylindrical joint element.
- The governor arms (and hence the sleeve) are spinning with angular velocity 3.147 radians per second.
- The sleeve is sliding upward on the shaft with velocity 4.5 mm/sec.
The initial velocity of the entire system may be specified simply by specifying the initial velocity of the cylindrical joint between the sleeve and the shaft, with id 1, as follows:
joint_id = "1"
trans_iv = "4.5"
rot_iv = "3.147">
- Besides joints, there are two other ways to specify initial velocity in MotionSolve models: One is using the Motion_Joint or Motion_Marker element, and the other is using the Body_Flexible, Body_Rigid, or Body_Point element.
- If there is a conflict among initial conditions specified using these various elements, the following precedence rule is applied: Motion elements override the joint elements which in turn override the body elements.
- The number of initial conditions should not exceed the total
number of degrees of freedom in the model.
- Thus, a system with one degree of freedom should have only one velocity initial condition. The constraints apply consistent velocities to the rest of the states in the model.
- A system with zero degrees of freedom should have no velocity initial conditions.
