Point Mass
Model ElementBody_Point defines a point mass entity in MotionSolve.
This entity has mass, but no inertia properties. The position of a point mass is characterized by three translational coordinates. By default, the orientation of the point mass is set to be the same as the global coordinate system. It never changes during simulation.
Reference_Markers on Body_Point may have location and orientation coordinates. The orientation of these Reference_Markers does not change during the simulation.
<Body_Point
     id                  = "integer"
[    label               = "string" ]
     cg_id               = "integer"
[    lprf_id             = "integer" ]
     mass                = "real"
     v_ic_x              = "real"
     v_ic_y              = "real"
     v_ic_z              = "real"
     v_ic_x_flag         = { "TRUE" | "FALSE" }
     v_ic_y_flag         = { "TRUE" | "FALSE" }
     v_ic_z_flag         = { "TRUE" | "FALSE" }
</Body_Point>Attributes
- id
- Element identification number, (integer>0). This number is unique among all Body_Point elements.
- label
- The name of the Body_Point element.
- cg_id
- Specifies the Reference_Marker that is located at the center-of-mass of the Body_Point.
- lprf_id (optional)
- Specifies the local part reference marker.
- mass
- Specifies the mass of the Body_Point. Mass > 0.
- v_ic_x
- Specifies the initial translational velocities of the Body_Point CG Reference_Marker along the global x-axis.
- v_ic_y
- Specifies the initial translational velocities of the Body_Point CG Reference_Marker along the global y-axis.
- v_ic_z
- Specifies the initial translational velocities of the Body_Point CG Reference_Marker along the global z-axis.
- v_ic_x_flag
- A Boolean flag that indicates whether the x-velocity is known exactly or is just an initial guess.
- v_ic_y_flag
- A Boolean flag that indicates whether the y-velocity is known exactly or is just an initial guess.
- v_ic_z_flag
- A Boolean flag that indicates whether the z-velocity is known exactly or is just an initial guess.
The three body problem is one of the oldest problems in dynamical systems. The problem is to determine the behavior of three interacting celestial masses, for example the Earth, Moon and Sun. No closed form solutions have been found for the general problem and numerical simulations are performed to predict the behavior of the three bodies. The scale of the system is such that the three bodies can be considered as point masses.
- The mass of the Sun is 1.988 × 1030 kg.
- The mass of the Earth is 5.974 × 1024 kg.
- The mass of the moon is 7.475 × 1022 kg.
- The mass of the Sun is 3.328E+5.
- The mass of the Earth is 1.000.
- The mass of the moon is 1.251E-2.
- The distance from the Sun to the Earth is 1.496 x 108 km.
- The distance from the Moon to the Earth is 3.844 x 105 km.
- The distance from the Sun to the Earth is 389.2.
- The distance from the Moon to the Earth is 1.000.
- The time unit is set to 1 year (365 days), so a long term simulation can be performed.
- The velocity of the Earth with respect to the Sun is 29.8 Km/s. This is equivalent to 2.445 x 103 Moon-Earth distances per year.
- The velocity of the Moon with respect to the Earth is 3680 km/hr. This is equivalent to 83.86 Moon-Earth distances per year.
The global coordinate system is placed at the CG of the Sun. At the start of the simulation, the Earth is assumed to be along the X-axis of the global coordinate system. The moon is assumed to be in the X-Y plane as shown in the figure below.
Figure 1. The Sun-Earth-Moon System
The Body_Point defining the sun in this system of units would be:
<Body_Point
     id                  = "1"
     cg_id               = "11"
     mass                = "3.328E+5"
     v_ic_x              = "0.0"
     v_ic_y              = "0.0"
     v_ic_z              = "0.0"
     v_ic_x_flag         = "TRUE"
     v_ic_y_flag         = "TRUE"
     v_ic_z_flag         = "TRUE"
</Body_Point>The Body_Point defining the Earth in this system of units would be:
<Body_Point
     id                  = "2"
     cg_id               = "21"
     mass                = "1.0"
     v_ic_x              = "0.0"
     v_ic_y              = "2.445E+3"
     v_ic_z              = "0.0"
    </Body_Point>Comments
- A point mass in physics is an idealization of a body whose
                    dimensions are very small compared to the other distances which are relevant to
                    the problem. In such cases, the internal structure of the body can be neglected,
                    and the body can be treated as if its mass were concentrated at one point in
                         space.In some situations, the body can be treated as a point mass for some purposes even if its dimensions are not negligibly small. For example, the gravitational field outside a spherically-symmetric body is the same as if the body were a point mass positioned at the center (with the same total mass, acting as a point source of gravitation).
- Body_Point can be connected with the other bodies (point, flexible or rigid) with constraint and force elements. Any torque applied to Body_Point is ignored since it has no effect on the motion of the Body_Point .
- All constraint elements are supported. A few force elements are not supported. These are: Force_Beam and Force_Field.
