.#.#.#.dis file
The .#.#.#.dis file is a Patran 2.5 ASCII format results file.
File Creation
This file is created when the Patran format is chosen and normal modes analyses are performed. (See documentation for the I/O Option OUTPUT).
File Contents
| Result | Description |
| Eigenvector | Eigenvector results from
normal modes analyses. Output is controlled by the I/O Option DISPLACEMENT. |
- One such file is created for each calculated mode at each iteration where the I/O Option RESULTS requests analytical results to be output.
- The first # in the file name is the iteration number.
- The second # in the file name is the user-defined Subcase ID.
- The third # in the file name is the mode number.
