Sequential
Sequential analysis is any type of structural analysis performed on a structure under prior loading (also termed preloading or prestressing).
The response of a structure is affected by its initial state, which is affected by the preloading/prestressing applied prior to the analysis of interest. Examples of sequential analysis include analysis of rotorcraft blades under centrifugal preloading, pillar-like structures under compressive preloading, preload arising from the pretensioning of bolts on a structure, and so on. Use SimSolid to account for such preloading or prestressing effects.
You can add or remove loads from sequential analyses to simulate additional loading or unloading, respectively.
Structural 1 – Preload
Immovable 1
Nut tightening 1
Structural 2, Linked to Structural 1 – Loading
Immovable 1
Nut tightening 1
Force 1 – 20 N
Structural 3, Linked to Structural 2 – Unloading
Immovable
Nut tightening
*Force 1 deleted. Editing Force 1 to be 0 N has the same affect.
When the prestressing subcase is linear static, the prestressed stiffness matrix is given by:(1)
K ¯   =   K   +   K σ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaa0aaaeaaca qGlbaaaiaaykW7caqG9aGaaGPaVlaabUeacaaMc8Uaae4kaiaaykW7 caqGlbWaaSbaaSqaaiaabo8aaeqaaaaa@417D@
Where,
K ¯ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaa0aaaeaaca qGlbaaaaaa@36D2@
Prestressed stiffness matrix
K MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaae4saaaa@36C1@
Original stiffness matrix
K σ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaae4samaaBa aaleaacaqGdpaabeaaaaa@3836@
Geometric stiffness matrix that defines the prestressing. This is based on the stresses of the preloading static subcase.
Depending on preloading conditions, the resulting effect could be a weakened or stiffened structure.
  • If the preloading is compressive, it typically has a weakening effect on the structure (for example, column or pillar under compressive preloading).
  • If the preloading is tensile, it typically has a stiffening effect (for example, rotorcraft blade under centrifugal preloading).
When the prestressing loadcase is a non-linear static subcase, the prestressed stiffness matrix K ¯ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaa0aaaeaaca qGlbaaaaaa@36D2@ includes the geometric stiffness matrix K σ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaae4samaaBa aaleaacaqGdpaabeaaaaa@3836@ , and also accounts for the changes of K MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaae4saaaa@36C1@ due to the converged contact status carried over from the prestressing loadcase to the prestressed loadcase.
