SS-T: 4005 Structural Sequential Analysis
Run structural sequential (loading and unloading) analysis.
- Prerequisites
- Some features used in this tutorial are only available in SimSolid Advanced version. Please switch to Advanced to complete this tutorial.
- Purpose
- SimSolid performs meshless structural
analysis that works on full featured parts and assemblies, is tolerant of
geometric imperfections, and runs in seconds to minutes. In this tutorial,
you will do the following:
- Learn how to setup structural sequential analysis.
- Review results of sequential loading and unloading.
- Model Description
- The following model file is needed for this tutorial:
- tension_clip.ssp
Open Project
- Start a new SimSolid session.
On the main window toolbar, click Open Project
- In the Open project file dialog, choose tension_clip.ssp
- Click OK.
Create Structural Linear Analysis
Create Immovable Support
Create Bolt Tightening Load
Create Sequential Analysis (Loading Step)
Create Sequential Force
Create Sequential Analysis (Unloading Step)
Edit Solution Settings
- In the Analysis branch of the Project Tree, double-click on Solution settings: for Structural 1.
- In the Solution settings dialog, for Adaptation select Global+Local in the drop-down menu.
- Click OK.
- Right-click on Solution settings and select Apply to all analyses in the current design study to apply the global+local adaptation to all other analyses in the study.
Run Design Study
Solve all analyses in the design study.
