Identify groups of parts that are disconnected from the model.
        A disconnected group of parts is defined as one or several parts that have
            Connections within the group, but no Connections with the other parts in the assembly. A
            model with disconnected groups of parts is likely to fail during the analysis. For
            instance, due to the ability of the disconnected groups to move without strain as rigid
            bodies, which results in numerical instability in Structural analysis.
                On the Project Tree, click
                    on the Connections workbench
                In the Connections workbench click the
 (Show disconnected groups) icon.
                A dialog will appear that displays a list of disconnected groups in the
                    model and are ordered most to least connected. The groups are automatically
                    highlighted in the model when browsing through the list in the dialog. The
                    selected group can be easily located in the assembly using auto-zoom in/out
                    buttons. A disconnected group of parts can be deleted or suppressed if
                    necessary.
                Connect groups.
                        In the Disconnected groups of parts dialog, press
                                    Control +
                                    Shift and then
                            click to select groups you want to connect.
                        Click Connect.
