Review Part Connection Locations
Diagnose connection problems.
- An easy way to sort connections by their distance to connected parts.
 - method to review connections in terms of their location and find ill-defined connections and connections with insufficient contact resolution level.
 - In the case of big gap/penetration tolerances, this dialog helps to find through-part connections which are physically incorrect and may result in numerical instability.
