Review Part Connections
Review connections on selected parts.
- In the modeling window, right-click on a part of the model.
                In the context menu, select Review part
                        connections.
                A dialog will open and show a list of all connections for the selected part. Connections can be edited and deleted from this dialog.
 - Optional: You can select the Show connected parts check box to see parts connected to your selection in the modeling window.
 - Optional: You can select the Show not connected neighbor parts check box to show them in the modeling window.
 - Optional: You can select the Group interconnections only check box to limit displayed connections to those within the part group.
