Define a stress versus strain curve that is referenced by a non-linear material
        property.
        SimSolid assumes an engineering stress-strain curve.
                    - Engineering stress
                    - Assumes a constant non-changing cross-section area during deformation.
                    - True Stress
                    - Assumes the cross-section area that changes at every instant during
                        deformation.
Some sources use true stress-strain curves. They can be imported by SimSolid from a CSV file.
                In the Project Tree, click on the Assembly branch to
                    open the Assembly workbench.
                On the workbench toolbar, click the
 (Apply materials) icon.
                In the dialog, choose a material to activate the Stress-strain curve
                    button.
                Click the Stress-strain curve button.
                In the Stress-strain curve dialog, use one of the
                    following methods to define a stress-strain curve:
| Method |
Process |
                        | Import from CSV |
                                - Click the Import CSV button.
                                - In the File browser, choose the desired CSV and click
                                        Open.
                        | Create from N-values |
                        Create stress-strain curve using a K-n power law function.
                                - Click the Create by n-value button.
                                - Specify K and n.
Some sample K-n values for typical materials are given in the
                            drop-down menu. |
                        | Create manually |
                                - Select the Add row button.
                                - Enter the stress and strain values. At minimum, 3 points are
                                    required.
                The results will be plotted in the XY
                    graph in the dialog. You can use the scroll wheel to zoom in, the left mouse
                    button to pan, or the Refit button to reset the
                    graph.
- Optional:
                Click the Edit elasticity modulus button to update the
                    elasticity modulus of a selected material.
The stress-strain curve is automatically updated to reflect the
                    elasticity modulus entered.
If the elasticity modulus defined is less than
                        the elasticity modulus derived from the curve, the stress-strain curve is
                        trimmed by intersecting the line that defines the new elasticity modulus and
                        the stress-strain curve.
Note: If an x-value input is outside the range of
                            x-values specified on the Table, the corresponding y-value look up is
                            performed using linear extrapolation from the two end
                    points.
