SS-V: 6020 Simply Supported Thin Square Plate - Transient Forced Vibration Response
Test No. VD03 View transient response of a simply supported square plate subjected to uniform forced vibration.
Definition
A simply supported thin square plate 10 x 10 x 0.05 m is subject to suddenly applied uniform pressure P=100 Pa which remains constant in time. Find peak dynamics response of the plate.
Sixteen (16) modes are used to approximate dynamics solution and 2% modal damping is assumed in all modes.
- Properties
 - Value
 - Modulus of Elasticity
 - 2.e+11 Pa
 - Poisson's Ratio
 - 0.3
 - Density
 - 8.e+3 kg/m3
Results
| Peak Time, sec | Deflection Y, mm | Surface Stress, MPa | |
| 0.213 | -3.46 | 2.311 | SimSolid, solid model |
| 0.210 | -3.52 | 2.41 | Reference, thin plate model |
Figure 2. Transient Response Evolution in the Plate Center
