SS-V: 6040 Simply Supported Thin Square Plate - Random Forced Vibration Response
Test No. VD05 View random response of a simply supported square plate subjected to uniform forced vibration.
Definition
Sixteen (16) modes are used to approximate dynamics solution and 2% modal damping is assumed in all modes.
- Properties
 - Value
 - Modulus of Elasticity
 - 2.e+11 Pa
 - Poisson's Ratio
 - 0.3
 - Density
 - 8.e+3 kg/m3
Results
Figure 3.
Figure 4. Distribution of Y-displacement PSD
| PSD Y-displacement,
                                             mm2/Hz  |
                                PSD Surface Stress X,
                                             MPa2/Hz  |
| 2081 | 1028.2 | SimSolid, 3D Solid model |
| 2063.2 | 1025.44 | Reference, thin plate model |
