Submit Jobs
Schedule jobs to run on an HPC cluster by submitting them to the Workload Manager.
- Right-click a job input file, such as an Optistruct .fem file, and choose a solver to submit a job using defaults for the job arguments pre-defined by your site's system administrator.
- Create a profile, a customized shortcut for submitting a job. A profile allows you to populate solver job arguments and save the information. You can later use the profile to quickly submit a job.
- Populate a job submission form containing all the arguments necessary to submit a job for a solver.
Once a job is submitted, it is placed into a queue awaiting execution. Jobs can be monitored for queuing, execution, and completion, and the job results viewed via the Jobs tab.
