App Composer
Access Web provides an easy way to create a user defined application definition (app def) using the App Composer.
- Add executable commands
- Add pre and post job execution scripts
- Manage app def parameters
- Test and onboard app defs
You can now create application definitions in Access Web without depending on the site administrator or editing XML files.
- Edit the application definitions
- Publish a local application definition
- Publish and Unpublish a global application definition
- Share an application definition
- View a shared application definition
- Clone an application definition
- Delete an application definition
