Visualize Results
Visualize plots and animations from the result files.
- View results from the Files and Jobs tab
- View auto refresh plot data for a running job from the Jobs tab
- Create and view customized Plot Template results
- Create a plot template from a completed and running job result file.
- Based on the result file information, the templates are categorized and saved
- Set a default template to view plot results directly
- Edit the X and Y parameters of the plot
- Show and hide curves on the plot curves
- Show and hide data points on the plot curves
- Save a plot as an image
- Save a plot with the selected data
- Visualize the saved plot
- Overlay plots to compare the results
