PollEx
PollEx
2023
  1. Home
  2. PollEx Tutorials
    Discover PollEx functionality with interactive tutorials.
  3. Solver Tutorials
    This section contains the tutorials for the following tools: PI, SI, SI Explorer, and Thermal.
  4. SerDes Tutorial
  • What's New
  • Get Started
  • PollEx Tutorials
  • PollEx User Guides
  • PollEx Installation Guide
  • Character String Search Rule
Index
PollEx
2023
PollEx
  • What's New
    View new features for PollEx 2023.
  • Get Started
  • PollEx Tutorials
    • Manufacture Tutorials
      This section contains the tutorials for the following tools: Block JIG Generator, Compare GDSII, Gerber to PCB, Make Board Paneling, Metal Mask Manager, Mounting Data Extractor, Mounting Emulator, Router-Machine JIG Generator, Solder Quantity Calculator, Soldering Pallet, Test Point Location Generator, and Underfill.
    • Modeler Tutorials
      This section contains the tutorials for the following tools: BOM, CAM, Component Arrangement Plan, CP, Golden Sample, Logic, PCB, Redmark+, and Worksheet Planner.
    • Solver Tutorials
      • PI Tutorial
      • SI Tutorial
      • IBIS-AMI Tutorial
      • SerDes Tutorial
        • Assign SerDes Model to Controller
        • Assign SerDes Model to Connector
        • Define the Frequency range for SerDes Analysis
        • Network Analysis (Waveform)
        • Network Analysis (Eye-diagram)
        • Network Analysis (Statistical Eye)
        • Network Analysis (Bathtub Curve)
      • MCP Tutorial
      • SI Explorer Tutorial
      • Thermal Tutorial
        In this step, you will complete operational steps of the thermal analysis tool.
    • UPE Tutorial
    • Verification Tutorials
      This section contains the tutorials for the following tools: DFA, DFE, DFE+, DFM, and Logic DFE.
    Discover PollEx functionality with comprehensive user guides.
    Instruction to install PollEx 2023.
    Definition for meta character using in making sentence for searching option.
PollEx
PollEx
2023
  1. Home
  2. PollEx Tutorials
  3. Solver Tutorials
  4. SerDes Tutorial
  • What's New
  • Get Started
  • PollEx Tutorials
Index
SerDes Tutorial
