Viscosity Models
This section describes the parameters for properly enabling various viscosity models.
- The aeration-viscosity coupling has been deprecated as practical use of these models was not viable (need for model calibration, lack of manufacturer specifications).
 - The existing temperature-viscosity coupling model commands have changed format and are now incorporated into the new viscosity models section.
 - Cross model non-Newtonian fluids are now available in nanoFluidX, also conveniently associated with the viscosity model section.
- If these simulation parameters are kept false, then the standard dynamic viscosity definition in the Phases Parameters takes precedence.
 - If either varvisc_temperature or varvisc_non_Newtonian are enabled (set to true), and a fluid phase is missed in the Viscosity Models section - the missed fluid will be assumed Newtonian and the standard dynamic viscosity definition from the Phase Parameters is assumed. It is best practice that if either varvisc_temperature or varvisc_non_Newtonian are enabled, you proceed using the Viscosity Models section for definition of all phase viscosity models.
For more information about viscosity models, refer to Viscosity Models in the Theory Manual.
Commands
viscosityModels
	viscosityModel
		viscosityModel_type        FLUID_NEWTONIAN
		viscosityModel_phase       1
		viscosityModel_visc        1e-3
	viscosityModel
		viscosityModel_type        FLUID_S_CROSS
		viscosityModel_phase       3
		viscosityModel_k           1.0
		viscosityModel_n           0
		viscosityModel_visc_0      1e-3
		viscosityModel_visc_inf    1e-3
	viscosityModel
		viscosityModel_type        FLUID_T_POLYNOMIAL
		viscosityModel_phase       4
		viscosityModel_c           "1e-3 0.0 0.0 0.0 0.0"
	viscosityModel
	       viscosityModel_type         FLUID_T_SUTHERLAND
	       viscosityModel_phase        5
	       viscosityModel_visc_ref     1.716e-5
	       viscosityModel_temp_ref     273.15
	       viscosityModel_temp_sut     110.4
	viscosityModel
	       viscosityModel_type         FLUID_T_POWER_LAW
	       viscosityModel_phase        6
	       viscosityModel_visc_ref     1e-3
	       viscosityModel_n            0
| Command | Contents | SI Unit Example |
| viscosityModel_type | Viscosity model choice which will be assigned to the
                                    respective fluid phase (viscosityModel_phase) Options
 Attention: Only one model can be selected
                                            per phase.
| viscosityModel_phase | Phase ID of the fluid phase which is affected by the selected model choice. | |
| viscosityModel_visc | Dynamic viscosity when using the Newtonian fluid
                                        model. Default = 0.001  |
                                [Pa.s] |
| viscosityModel_k | Dimensionless coefficient k for the Cross model (see Viscosity Models for more
                                        information). Default = 0.001  |
| viscosityModel_n | Serves as a dimensionless power exponent in the Cross model
                                    for non-Newtonian viscosity and Power Law temperature dependence
                                    more information). Default = 0.0  |
| viscosityModel_visc_0 | Zero shear rate viscosity for the Cross model. Default = 0.001  |
                                [Pa.s] |
| viscosityModel_visc_inf | Infinite shear rate viscosity for the Cross model. Default = 0.001  |
                                [Pa.s] |
| viscosityModel_c | Coefficients for the temperature-viscosity polynomial model.
                                    This is a vector variable, comprising of 5 values defined in
                                    order of the polynomial. Default = "0.001 0.0 0.0 0.0 0.0"  |
                                [Pa.s, Pa.s/T, Pa.s/T2, Pa.s/T3, Pa.s/T4] |
| viscosityModel_temp_ref | Base temperature of the Sutherland temperature-viscosity
                                    dependence model. Default = 273.15  |
                                [K] |
| viscosityModel_visc_ref | Base viscosity of Sutherland temperature-viscosity dependence
                                        model. Default = 0.00001716  |
                                [Pa.s] |
| viscosityModel_sut | Sutherland temperature (also known as Sutherland's
                                        coefficient). Default = 110.4  |
                                [K] |
