LS-DYNA Interface
New Features
- Contact Penetrations Check from Solver output files
- This new feature in the Penetration Check Tool allows directly reading the contact penetrations written by the solver in the messag or d3hsp files
 - The penetrations are then populated in the Penetration Check Browser and fixed using the functionalities of the tool
 - This new feature is activated by the new option "Check method"
                                    in the Penetration Check Entity Editor
 - Time Step Mass in Mass Summary Tool
- A new option in the Mass Summary Tool enable the calculation of the solver numerical added mass due to the elemental time step
 - From the guide bar, click
 and
                                    select the Consider Time Step Mass
                                        checkbox.
Figure 2. - The corresponding Time Step Mass column and total values are
                                    then display in the UI:
Figure 3.
 - New Initial State Entity
- The INITIAL_STRESS_(OPTION) and INITIAL_STRAIN_(OPTION) keywords are migrated to the new Initial State entity
 - The Initial State Entity is used to import and export the INITIAL_STRESS_(OPTION) and INITIAL_STRAIN_(OPTION) keywords, but not for creation or edition of the data in the session
Enhancements
- New Keywords supported
- Constrained Keywords: CONSTRAINED_SPR2
 - Contact Keywords: CONTACT_2D_AUTOMATIC_(OPTION) and CONTACT_FORCE_TRANDUCER_ID
 - Control Keywords: CONTROL_FORMING_TRIMMING, CONTROL_ACOUSTIC_SPECTRAL, CONTROL_ACOUSTIC_COUPLING, and CONTROL_IMPLICIT_SSD_DIRECT
 - Material Keywords: MAT_SPRING_MUSCLE and MAT_EXTENDED_3-PARAMETER_BARLA
 - Updated Keywords as per R13.1 manual
- Airbag Keywords: AIRBAG_PARTICLE
 - Constrained Keywords: CONSTRAINED_NODAL_RIGID_BODY
 - Control Keywords: CONTROL_ACCURACY, CONTROL_TERMINATION, CONTROL_SHELL, CONTROL_IMPLICIT_EIGENVALUE, and CONTROL_IMPLICIT_SOLVER, CONTROL_ADAPTIVE
 - Database Keywords: DATABASE_BINARY_D3PLOT, DATABASE_BINARY_D3DUMP, DATABASE_BINARY_DEMFOR, and DATABASE_BINARY_INTFOR, DATABASE_EXTENT_BINARY
 - Interface Keywords: INTERFACE_SPRINGBACK_(OPTIONS)
 - Section Keywords: SECTION_SOLID
 - Elements Entity Editor
 - The description of the Elements Entity Editor is updated and aligned to the solver manual description
 - Solver Mass Entity
 - The node selector is activated in the entity table
Resolved Issues
- Drive Mapping now considers INCLUDE_PATH when defined in the deck
 - ELEMENT_MASS defined on free node in old HM binary file are correctly converted to Solver Mass entity
 - Correction of transformations calculation using POINT definition. Previous transformations are now correctly applied on the POINT coordinates
 - Correction in reading MAT_SAMP-1 when followed by a PGP encryption block
 - Correction of SET_PART_TREE format in exported deck, when more than 8 entities are referenced
 - If the EC attribute is not used in MAT_FABRIC and it is defined in a deck, it will be read and maintained on export
 - In Material keywords with AOPT attribute, if any attribute is defined but not compatible with the AOPT value, those attributes will be read and maintained on export
 - Some entities, like Accelerometers, are automatically renumbered when an ID conflict is detected.
 - Correction of the dynamic graphical update of CONSTRAINED_NODAL_RIGID_BODY when updating the secondary node set in case of SET_NODE_ADD
 - Correction of graphical visualization of CONTACT involving PART of BEAM elements. The 3rd node of the beam is no longer taken into account
 - SET_NODE referenced in CONSTRAINED_INTERPOLATION is no longer found as unused
 - Model checker check "Tied contacts having common nodes" correctly considers only contact of type Tied
