Radioss Interface
New Features
- Support of the new Radioss 2023 profile
 - Joint Creation Tool
- This new tool enables the automatic creation of KJOINT2 and CYL_JOINT elements, as well as the rigid attachments of the joint to the selected connected parts
 - The tool is accessible from the Model Ribbon:
 - Time Step Mass in Mass Summary Tool
- A new option in the Mass Summary Tool enable the calculation of the solver numerical added mass due to the elemental time step
 - From the guide bar, click
 and
                                    select the Consider Time Step Mass
                                        checkbox.
Figure 3. - The corresponding Time Step Mass column and total values are
                                    then display in the UI:
Figure 4.
Enhancements
- New Starter Keywords supported
- /EOS/TABULATED
 - /FAIL/INIEVO
 - /FAIL/SYAZWAN
 - /FAIL/TAB2
 - /SENSOR/TEMP
 - /TRANSFORM/POSITION
 - New Engine Keywords supported
- Multiple new output options supported in /H3D/ELEM
 - Multiple new output options supported in /H3D/NODA
 - Multiple new output options supported in /H3D/SHELL
 - Multiple new output options supported in /H3D/SOLID
 - Updated Starter Keywords as per Radioss 2023 manual
- /BEAM: 3rd node made optional
 - /INTER/TYPE8: New attribute Fn_last and Ft_last
 - /INTER/TYPE18: New attribute Igap
 - /MAT/LAW62: New attribute Form and Poisson ratios
 - /MAT/LAW88: New attribute value Tension=-2
 - /PROP/TYPE14: New attribute Iale
 - /RBODY: New attribute Ifail
 - /SENSOR/DIST: New attribute Tmin and Dflag
 - Support on nested SUBMODELs
 - Elements Entity Editor
 - The description of the Elements Entity Editor is updated and aligned to the solver manual description
 - Rigid Body Manager
 - The Rigid Body Manager is replaced by the new Rigid Body creation controller
Resolved Issues
- Correction in reading the Engine keywords /DT/AMS
 - Correction of the dynamic graphical update of /RBODY when modifying the node set in case of a formula set
 - Correction in reading /VISC/PRONY when the keyword is encrypted
 - Correction in reading and exporting Area and Inertia attributes in /PROP/BEAM when Beamsection is Unresolved
 - In some cases, /GRNOD/NODE referred into /INTER keyword was exported as an empty /GRNOD/GENE set. This issue is now corrected.
 - CYL_JOINT is now implemented correctly.
