Define nodal initial conditions for the simulation. You can define nodal initial conditions on the nodes of selected
surfaces and solids, nodes within zones, and nodes of solids on the side of a plane.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE
studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
Nodal Initial Conditions
Define nodal initial conditions for the simulation. You can define nodal initial conditions on the nodes of selected surfaces and solids, nodes within zones, and nodes of solids on the side of a plane.
Simulation
Run AcuSolve, track solver and meshing jobs, and plot run time data.
