Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE
studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
Prepare your model for wind tunnel analysis using ultraFluidX.
Attention: The icons shown on the ribbon below are used to
complete this workflow. Click an icon to learn more about the tool.
Transfer Data
After preparing your model, use the Data Transfer tool to transfer mesh data to the environment used for aerodynamic and aeroacoustic setup.
