HyperMesh CFD
HyperMesh CFD
2023
  1. Home
  2. Automation
    Automate simulation processes with templates and utility scripts.
  3. Python API
    Use python based automation to quickly setup HyperMesh CFD for ultraFluidX simulations in batch mode.
  4. Case Setup Python API
    Documentation of HyperMesh CFD for ultraFluidX simulation case setup.
  • What's New
  • Get Started
  • Learning Center
  • Solution Layers
  • Manage Files and Data
  • Convert
  • Geometry Modeling
  • Meshing
  • Setup
  • Post-Processing
  • Automation
  • Design Exploration
  • Solver Help
Index
HyperMesh CFD
HyperMesh CFD
  • What's New
    View new features for HyperMesh CFD 2023.
  • Get Started
  • Learning Center
    Discover HyperMesh CFD functionality with interactive tutorials and community resources.
  • Solution Layers
    Solution-centric workflows allow you to traverse through modeling environments using a dedicated UI layer.
  • Convert
    Use the Convert tool to convert entire models between data types.
  • Geometry Modeling
    Manage CAD, FE, and 2D parametric sketch geometry.
  • Meshing
    Generate surface/volume mesh by defining mesh controls, or interactively create and edit 2D surface mesh.
  • Setup
    Prepare your model and run the simulation.
  • Post-Processing
    Post-process the simulation results by creating visualizations and measurements.
  • Automation
    • Template Manager
      Use the Template Manager to define rule-based logic for groups, geometric operations, and setup and automate simulation processes.
    • Python API
      • Case Setup Python API
        • Load Data
          Use basic Inspire API to load data.
        • Tunnel
          Create a wind tunnel.
        • Turbulence
          Create a turbulence generator.
        • Part Types
          Identify parts.
        • Belts
          Create a belt system.
        • Mesh Controls
          Create mesh refinement zones.
        • Result Outputs
          Define result output types.
        • Material
          Create a new fluid material.
        • Output Controls
          Set output parameters.
        • Simulation Controls
          Set simulation parameters.
      • precursorRun Script
        The precursorRun script is a standalone command line utility that generates the .xml input files to run two simulations: a precursor ultraFluidX simulation with coarser mesh and fast turnaround time and a user desired ultraFluidX simulation starting from the results generated by the precursor simulation.
    • hwCFDReport
      Post-processing utility that uses results from CFD simulations to generate a PowerPoint report containing images, animations, and graphs of the results from the simulation.
    Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
  • Solver Help
    More resources for AcuSolve and ultraFluidX solvers.
HyperMesh CFD
HyperMesh CFD
2023
  1. Home
  2. ...
    • Automation
    • Python API
  3. Case Setup Python API
  • What's New
  • Get Started
  • Learning Center
  • Solution Layers
  • Convert
  • Geometry Modeling
  • Meshing
  • Setup
  • Post-Processing
  • Automation
  • Solver Help
Index
ON THIS PAGE
    Learn more about Inspire Python API and explore Quickstart Demos.
    • Load Data
    • Tunnel
    • Turbulence
    • Part Types
      Identify parts.
    • Belts
    • Mesh Controls
    • Result Outputs
    • Material
    • Output Controls
    ON THIS PAGE
