Use the Vortex Core tool to identify regions in the flow where vortices
exist.
The algorithm works by interrogating the velocity field to identify local regions of
rotating flow then displaying the center of rotation as a line. These line segments
can be visually inspected to identify large scale vortex structures within the flow.
For transient cases, tracking the motion and interaction of the vortex cores
provides some indication of the local acoustic properties of the flow.
Note: This calculation can be expensive for large
models.
A couple notes regarding vortex cores:
From the Post ribbon, Clips tool group, click the Vortex
Core tool.
Select solid volumes on which to detect vortex cores.
Click Vector Variable on the guide bar then select a source field option in the microdialog.
Click Calculate.
Use the display properties microdialog to adjust the
visualization of the vortex cores.
- Optional:
Toggle Threshold and select a type.
Applying a threshold to the vortex core helps to eliminate smaller, less
important vortex core lines for a clearer visualization.
- Vorticity magnitude
- Normalized vorticity magnitude. Value of vorticity magnitude /
maximum vorticity magnitude for the calculated vortex core
entity.
- Vortex core length
- Normalized vortex core length. Value of vortex core length /
maximum vortex core length for the calculated vortex core
entity.
On the guide bar, click one of the following:
Restriction: Vortex cores cannot currently be hidden
with clips.
