NX Reader
NX import is available through two different readers: UGOpen native reader and a third-party non-native reader.
View new features for HyperMesh CFD 2023.
Discover HyperMesh CFD functionality with interactive tutorials and community resources.
Solution-centric workflows allow you to traverse through modeling environments using a dedicated UI layer.
File formats supported.
Create a new file.
Open a file.
Import an existing file to the current session.
Learn about the supported CAD readers and the options available for importing CAD geometry data.
CAD readers supported by the application.
The NX reader utilizes the UGOpen library to read files from NX.
The NX Third Party reader does not need a valid NX installation or license to access these libraries.
CAD readers provide options for processing data during import.
Each reader reads the CAD file and stores the geometry information. When a CAD file is read, a .msg file is created (or appended to) in the current working directory.
Learn about possible difficulties you may encounter during CAD import.
The metadata names generated by the CAD readers are composed of a general prefix followed by a metadata specific name.
The prefix is specified using the @MetadataPrefix option in each _reader.ini file.
Import FE models for supported solver interfaces.
Use reader options to control the behavior of the code when reading results from disk.
Save all of the data in your current session.
Export FE data in your current session.
Record a video or take a snapshot of the screen.
Quickly import and export templates containing full simulation settings, part definitions, or mesh controls.
Use the Convert tool to convert entire models between data types.
Manage CAD, FE, and 2D parametric sketch geometry.
Generate surface/volume mesh by defining mesh controls, or interactively create and edit 2D surface mesh.
Prepare your model and run the simulation.
Post-process the simulation results by creating visualizations and measurements.
Automate simulation processes with templates and utility scripts.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
More resources for AcuSolve and ultraFluidX solvers.
