Perform Batch Repair
Use the Defeature: Batch tool to perform automatic cleanup operations on selected surfaces.
Note: This feature is not supported for a model with discrete geometry.
  1. From the Geometry ribbon, click the Defeature > Batch tool.
  2. On the guide bar, click to define batch repair options.
  3. Select surfaces to clean up.
  4. On the guide bar, click Batch Repair.
