Fix Mesh Quality of Tessellated Models
Use the Fix tool to improve the quality of an FE (discrete/mesh) model.
This tool works for FE models only and helps to improve the quality of selected FE surfaces using defined parameters.
  1. From the Mesh ribbon, click the arrow next to the Mesh tool set, then select Fix.
  2. On the guide bar, click to define the criteria for quality improvements.
  3. Select the surfaces to fix.
  4. Click Fix on the guide bar.
Note:
  • All selected cleanup operations are performed in sequence using the same order listed in the options menu.
  • If you have a CAD geometry model with mesh and you want to improve its quality, first convert it to an FE model using the Convert tool.
