Use quick advanced selection to associate a preferred advanced selection method to different entity types. The advanced
method becomes instantly accessible while holding the Alt key during any selection action.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE
studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
Append and remove individual entities
to/from your selection by holding Ctrl while
left-clicking.
To extend your selection from a selected entity to a target entity, hold Shift
while left-clicking.
In the modeling window:
Append entities to your selection by
holding Ctrl while left-clicking.
Remove entities from your selection by
holding Shift while left-clicking.
Clear your selection in the following ways:
Left-click in empty space.
Note: Only available in idle
mode.
Click on an active entity selector.
Press Esc.
Tip: In the aerodynamics and aeroacoustics setup environment, holding
Ctrl turns selected parts transparent, enabling you to
select or deselect the parts behind them. Deselect transparent selected items by
clicking on their edge lines.
