@checkfile()
Checks for a file.
@checkfile (file name)
HyperMesh Template Function
- file name
- File name to be checked.
*text()
*if([@checkfile(\tmp\file)=1])
*string("file exists")
*else()
*string("file does not exist")
*endif()
*output()
Return 1 if the file exists. On a PC, use backslashes for the path (\tmp\file). On Unix, use forward slashes for the path (/tmp/file).
