@getentitydefaultstatus()
Retrieves the default status of attribute/dataname of an entity. Returns true if the default status is OFF, or false otherwise.
@getentitydefaultstatus (entity type, entity id, data_name)
HyperMesh Template Function
entity type
The type of entity, such as sets, elems, or nodes, to which entity id refers.
entity id
The ID of the entity you want to reference.
data_name
The data name of the entity. For example, ID, name, node1.globalx.
Examples
To get the default status of attribute BCTPARM_REFINE_VAL from property 1:
@getentitydefaultstatus(props,1,BCTPARM_REFINE_VAL)
Version History
2019
2021.1
See Also
*entitypointerset()
