@stringstartswithnumericcharacter()
Checks if a string starts with a numeric character.
@stringstartswithnumericcharacter (string)
HyperMesh Template Function
- string
- The string to check.
*components("")
*format()
*if([@stringstartswithnumericcharacter (name)])
*string("Component name starts with numeric character: ")
*field(string,name,0)
*end()
*endif()
*output()
Returns 1 if the string starts with a numeric character, otherwise, 0.
None.
