@defined()
Tests to see if a dictionary item or an attribute is defined.
@defined (dictionary item|attribute_name)
HyperMesh Template Function
- dictionary item
- The name of a dictionary item. This function returns 1 if the dictionary item is active or 0 if the dictionary item is not active. If the dictionary item does not exist, the function returns 0.
- attribute_name
- The name of the attribute.
This function allows dictionary items to be set as a toggle that you can turn off and on. During translation, @defined() can be used to see if the item has been toggled on or off.
If the attribute with the given name is defined on this entity, the function returns 1; otherwise, it returns 0. If it cannot find the attribute on the current entity, @defined will also check the dictionaries. hm_defined does not check the dictionaries because the dictionaries cannot be accessed outside the template.
