*menuattributecreate()
Initializes an attribute to a specified value upon creation of an entity.
*menuattributecreate (attribute, expression)
HyperMesh Card Previewer Command
attribute
The name of the attribute to hold the value.
expression
An expression defining the value.
*menuattributecreate() can only be used for integer, real, entity, or string attributes.
