*menuinitialarrayvalue()
Sets the initial values of an attribute.
*menuinitialarrayvalue (value)
HyperMesh Card Previewer Command
- value
- Can be an expression for a real or integer attribute, or a string for string attributes.
This command works only for attributes declared as arrayofints, arrayofreals, or arrayofstrings. Initially, all values in the array are set to the specified value. After the initial values are set, whenever the array size is increased, all new items in the array are set to the new value.
