*menuattributeset()
Sets the value of attribute.
*menuattributeset (attribute, expression)
HyperMesh Card Previewer Command
- attribute
 - The name of the attribute to hold the value.
 - expression
 - An expression defining the value.
*menuattributeset() can only be used for integer, real, entity, or string attributes.
