*menucounterset()
Sets the value of the local counter.
*menucounterset (counter, value)
HyperMesh Card Previewer Command
- counter
- Value from counter1 to counter20 indicating which of the 20 possible counters should be set to the value parameter.
- value
- Value of the counter.
Unlike the *counterset() command that sets a global value for the entire output section of the template, the *menucounterset() command's value is only for the local scope of an entity as specified by the *beginmenu() and *endmenu() commands.
