HMIN_close()
Closes hminlib.
void HMIN_close(void);
HyperMesh hminlib Function
Closes hminlib.
None.
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Closes hminlib.
Determines if HyperMesh combines loads on the same node.
Provides a way to convert the name of an entity to the entity type used in HyperMesh.
Sets a flag to delete, or not delete, empty components.
Retrieves the name of the file being read for input.
Initializes hminlib. This function must be called before using any other function in hminlib.
Will overwrite or not overwrite entities when the option ‘FE overwrite’ is selected during feinput import.
Allows hminlib to read in all of the entities in the database.
Controls the way HyperMesh resolves the conflict when an incoming entity has the same name as an existing entity.
Sets the solver type for feinput.
Sets the view to the desired angle as read in the translator.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
Closes hminlib.
Closes hminlib.
Closes hminlib.
None.
