HMIN_init()
Initializes hminlib. This function must be called before using any other function in hminlib.
FILE * HMIN_init(char * formatname, char * version, int argc, char * argv[]);
HyperMesh hminlib Function
- formatname
- A character string set to the name of the translator.
- version
- The version number of the translator that is being written.
- argc
- Number of arguments passed in from the C function main.
- argv[]
- Argument passed in from the C function main.
HMIN_init calls HM_setterminatefunction() to terminate hminlib. If you want to call HM_setterminatefunction() and set your own terminate function, you must call it after HMIN_init. HMIN_message_close should be called by your new terminate function.
None.
