HMIN_setduplicatenameseparator()
Controls the way HyperMesh resolves the conflict when an incoming entity has the same name as an existing entity.
void HMIN_setduplicatenameseparator(char separator);
HyperMesh hminlib Function
If an incoming entity has the same name as existing HyperMesh entity, it is necessary to generate a new name to avoid the conflict. By default, HyperMesh appends to the name a period followed by a number, for example: "materialname.1". This pattern is unacceptable to some solvers, such as Abaqus, that can not have a period in a name. This command controls what to use in place of a period.
separator
Any printable character, ASCII 32-126.
HMIN_setduplicatenameseparator(':');
None.
