HMMOD_elementgetcentroidalresult()
Retrieves the centroidal result of an element specified by element pointer, layer, and index.
float HMMOD_elementgetcentroidalresult(void * elementptr, int layer, int index);
HyperMesh hmmodlib Function
- elementptr
- The pointer to the element.
- layer
- The layer where the centroidal result is stored.
- index
- The index to the array of centroidal results.
The result at the centroid of the specified element.
None.
