annotation measure
Create, delete, and edit measures.
annotation measure create <type><label>
annotation measure curve <name>=<value>
annotation measure delete all
annotation measure delete <label>
annotation measure delete <range>
annotation measure global <name>=<value>
annotation measure <label> argument <name>=<value>
annotation measure <range> argument <name>=<value>
annotation measure rename <label> <new label>
Arguments
- create
- Create a measure.
- <type>
- The type of measure to create. Options include:
- staticminmax
- dynamicminmax
- minimumdistance
- distancebetween
- incrementaldistance
- relativedisplacement
- trueangle
- relativeangle
- anglebetween
- position
- nodalcontour
- elementalcontour
- nodepath
- circularradius
- yawpitchroll
- <label>
- The measure name.
- curve
- Create curves based on measures.
- delete
- Delete a measure.
- global
- Define measure display options.
- <label> add
- Apply parameters to the measure. <label> is the
measure name. Options include:
- type - <type>
- tracking - <true/false>
- resolved system - <system>
- add - <entitytype> <entity id>
- edit <item id> <entitytype> <entitytype>
- remove - <item id> <item id range>
- display – Display the following attributes:
- font=<font>
- fontsize=<fontsize>
- id=<true/false>
- name=<true/false>
- visibility=<true/false>
- system=<true/false>
- min=<true/false>
- max=<true/false>
- value=<true/false>
- distance=<true/false>
- nodepath=<true/false>
- magnitude=<true/false>
- Rectangular Systems
- x=<true/false>
- y=<true/false>
- z=<true/false>
- Spherical Systems
- r=<true/false>
- p=<true/false>
- t=<true/false>
- Cylindrical Systems
- r=<true/false>
- t=<true/false>
- z=<true/false>
- trueangle=<true/false>
- xprojection=<true/false>
- yprojection=<true/false>
- zprojection=<true/false>
- radius=<true/false>
- ctrx=<true/false>
- ctry=<true/false>
- ctrz=<true/false>
- <range>
- Apply parameters to the measure in <range>.
Options include:
- type - <type>
- font=<font>
- id=<true/false>
- name=<true/false>
- min=<true/false>
- max=<true/false>
- x=<true/false>
- y=<true/false>
- z=<true/false>
- Spherical Systems
- r=<true/false>
- p=<true/false>
- t=<true/false>
- r=<true/false>
- t=<true/false>
- z=<true/false>
- ctrx=<true/false>
- ctry=<true/false>
- ctrz=<true/false>
- rename
- Rename a measure.
- <label>
- Select the name of the measure you want to rename.
- <new label>
- Enter the new name for the measure.
Examples
annotation measure create Measure Group 3 staticminmax
annotation measure global Measure Group 3 transparency true
annotation measure rename Measure1 Measure2
annotation measure curve measure=4 singlecurve=true xaxis=Distance yaxis=X
annotation measure curve measure=4 livelink=true yaxis=Y
