annotation note
Create, delete, copy, and edit notes.
annotation note create <name>
annotation note delete all
annotation note delete <name>
annotation note <name> attach <name1>=<value1>
annotation note <name|range> copy
annotation note <name|range> display <name1>=<value1>
annotation note rename <name|range> <new label>
Arguments
- create
- Create a note.
- delete
- Delete a note.
- <name> attach
- The note attachment type. <name> is the note's
name. Attachment types include coordinate,
entity, and window.
- coordinates
- Attach the note to the XYZ coordinates.
x=<x>, y=<y>, z=<z> Enter the x, y, and z coordinates of the note. - entity
- Attach the note to an entity. Select one of the following
entity types:
component|element|node|system.
<id> Enter the entity ID. select Select an entity from the modeling window. - window
- Attach a note to the window.
x=<x>, y=<y> Enter normalized x and y screen coordinates between 0-1.
- <name|range> copy
- Copies a single note referenced by name or ID. To copy multiple notes, the range syntax is required.
- <name|range> display
- Note display settings. Options include:
- aligntext=<left/center/right>
- Aligns the note text.
- autohide=<true/false>
- Hide the note box when the entity that the note is attached to is not visible on the screen.
- bordercolor="<R> <G> <B>"
- bordercolor=<color>
- Select a color for the note box border. Enter RGB values, select <color> to display and select a color from the color palette, or select a color from the list.
- borderthickness=<0-4>
- Select a border thickness value to apply to the note box. Enter a value between 1-4.
- fillcolor="<R> <G> <B>"
- fillcolor=<color>
- Select a fill color for the note. Enter RGB values, select
palette, or select a color from the list.Note: This is deactivated if filltransparency=true.
- filltransparency=<true/false>
- Removes the color from within the note box and makes it transparent against the window.
- font=<font>
- Select the font type.
- fontsize=<fontsize>
- Select the font size. Enter a value between 8-48.
- movetoentity=<true/false>
- Positions the note at the attachment location. This option is disabled if Window is selected as the attachment type.
- positiontype=<screen/coordinates>
- Positions the note on a fixed xy screen position (values between 0 and 1) or on the xyz model coordinates.
- positionx=<x>
- Note x position.
- positionx=<y>
- Note y position.
- positionx=<z>
- Note z position (only valid for position type coordinates).
- screenanchor=<true/false>
- The note remains stationary during animation or when manipulating the model view. This option is disabled if Window is selected as the attachment type.
- shape=<rectangle,circle,ellipse>
- Select the shape of the note box.
- text=<text>
- Enter note text.
- textcolor="<R> <G> <B>"
- textcolor=<color>
- Select a color for the note text. Enter RGB values, select <color> to display and select a color from the color palette, or select a color from the list.
- visibility=<true/false>
- Display or hide the note from the modeling window.
- x=<x>
- The x coordinate of the note's location in the modeling window.
- y=<y>
- The y coordinate of the note's location in the modeling window.
- rename
- Rename a note.
- <name>
- Select the name of the note you want to rename.
- <name>
- Enter the note's new name.
Examples
annotation note create Note1annotation note delete allannotation note delete "Note 2"annotation note "Note 5" attach coordinates x=0.5 y=0.5 z=0.5annotation note "Note 4" attach entity component id "1 Solid 19"annotation note "Note 3" attach window x=0.5 y=0.5annotation note rename Note1 Note2annotation note "Note 1" display visibility=falseannotation note "Note 1" display x=3annotation note "Note 1" display y=3annotation note "Note 1" display textcolor=Redannotation note "Note 1" display text="Note 1"annotation note "Note 2" display aligntext=Centerannotation note "Note 2" display autohide=trueannotation note "Note 1" display bordercolor="255 255 255"annotation note "Note 3" display borderthickness=3annotation note "Note 3" display fillcolor="44 85 126"annotation note "Note 2" display filltransparency=falseannotation note "Note 2" font="Papyrus 10 normal roman"annotation note "Note 2" display fontsize=12annotation note "Note 2" display movetoentity=trueannotation note "Note 2" display screenanchor=trueannotation note "Note 2" display shape=ellipse
