kpi hotspot config
Import or export hotspot search criteria.
kpi hotspot config import <filename>
kpi hotspot config export <filename>
Arguments
import
Import search criteria. Use the file browser to select a file to import.
Note: When importing the hotspot search criteria, all of the queries being imported will take over the current set of hotspot search queries. The currently loaded search queries will be lost.
export
Export the hotspot search criteria in the form of a hotspot configuration file in the XML format. Use the file browser to save the config file to a specific location.
<filename>
The name of the file that contains the search criteria. Supported file type is *.xml.
Export the current settings to the config file test.xml:
kpi hotspot config export C:/Users/User1/Downloads/test.xml
